A buddy of mine just picked up a 97 80 series with front and rear ARBs. While we were going over it he turned on the compressor for the front diff and the compressor seemed to run a lot longer than it should. When it finally shut off you could distinctly smell gear oil from the engine bay.
Is this a bad O-ring and if so can it be fixed by pulling the third out or do I need to actually remove the third and pull the whole carrier assembly out?
