Leak from steering box
This my first new thread so here goes.
I have a 94 J80 and there a number of small things to repair on it. The steering is leaking fluid from the box. I bought the recammended fluid and I noticed that the old fluid was alot darker red then the new one; could this be part of the problem. I read on one of the threads that old fluid can cause a leak.
Thanks for anyone who can help.
I live in France but am Irish oringinally. I lved for ten years in Africa and I want to fix up the 80 for some new adventures in Africa. Just bought the 80 a few weeks ago so I'm getting used to working on 4x4s again. It's been over ten years since I Had one.
Thank God for the internet and especially this site :cheers: . It makes it so much easier to get info. I remember how we used to struggle to decent info on the old FJ 40's back in the the 1980s in Africa.
Thanks again
Where is it leaking from the box? Toyota sells a seal kit to R&R the box as the replacement cost is MAJOR coin. A flush would help...deteriorated fluid can be less viscous than the new stuff, but if it is a heavy leak it is probably not going away.
good luck!
I had the same problem with my 94. Had to rebuild the box. Not to tough if you take your time...
I lost a bit of new fluid so I didn't have enough to finish the job on saturday so I'm going to get some more tomorrow and hopfully after a good run I'll have some positive results. If not then I'll have to just dimantle it and put in a new seal kit. Only thing is it's 250euros over here for the kit.
Thanks for the replys :cheers:
