i found my coolant leak, it seems to be coming from atleast 2 hoses and maybe as many as 4 it is hard to tell if the upper ones are leaking on the lower or if they are leaking also. It looks like the 2 from the thermostat to the 2 metal lines bolted to the passenger side of the engine block for sure are leaking. the others are coming off the drivers side of the water pump. i top the coolant off every couple of weeks, do you guys think it would be fine to wait till spring for warmer weather? also it is green coolant, after i drain everything out for this should i stick with the green as to not shock this aging but reliable engine?
thanks for the input
