leaf spring tech
how do i work out what length of shackle is optimal for my leaf spring setup?
also since i did my 55 series rears, my front has not been flexing like it used to, and lifts wheels. i think it is because the 55 pack is too soft in the rear, which means that the rear does all the work, the fronts don't
i could soften the front, but i don't want to go lower in the front, so if i stiffen the rear by one leaf. or two, will this force the fronts to do their share?
Flaten your spring figure out what the furthest distance your spring will travel in the x direction from your hanger, your looking for a 45deg angle at this point so, simple trig tells us
x^2 + y^2 = hyp^2
at 45 x and y are equal
so
(2x^2)^(1/2) = hyp
hyp = shackle length
On my 60 wagon, I use longer shackles in the rear than in the front. They are 2 inches over stock in the rear, one inch over stock in the front (any longer and you get steering/wander issues). The anlgle of the shackle has a lot to do with the arch of your spring and mainleaf length. Longer shackles will be "pulled back" some, over a shorter one, causing a steeper angle. Some say a 45 degree shackle angle is ideal; I think in dealing with re arches, added leaves, etc that anything short of outright vertical is OK. My 60 has only 5 to 10 degrees from vertical angle to the shackles; and the ride is nice. This small angle also tells me that I got the max arch out of my spring for its length; a flatter spring would cause a more angled shackle. If I wanted more angle than 5 to 10 degrees and was convinced that this would give me better ride quality, I would have to have a longer mainleaf in the spring.
A longer shackle will put slightly more leverage on the leafs when flexing. (it is a longer lever). In my opinion the fronts and the rears operate independently. What you did to the rear should not affect the front flex much. Put on a longer shackle in the rear and see how it works. Then add leaves if it is still too soft. Especially on wagons, I like a little stiffer pack in the rear for carrying capacity.
I would run one inch over stock shackles in front and two over in rear. Assuming this fits your spring length as described above.
it all confuses me. the front used to flex great, then i put longer springs in the rear. the rear flexes awesome, the front keeps lifting wheels... hmm
i also figured maybe shocks were doing it, but i flexed her up till it lifted, marked it, took out the shocks, flexed it at the same spot and lifted at pretty much the same spot. same with the rear, but i borrowed some longer shocks, the rear flexes more (even though removing the shocks did not help????) and the front has maybe half of an inch more. the shocks have alot more up travel than down travel where the springs are sitting now.
i found this weekend on the trails that the front axle does not like to do much work, even though i know it's got more flex than it's displaying, which is why i thought the rear pack might be too soft compared to the front.
the front seemed to uptravel alot better down hill, down travel is still limited down hill, this partially suggests to me the front is alot stiffer than the rear, as the rear works fairly well down hill, and real well up hill.
is it true that a shackle that is too long will restrict travel?
