Leaded Gas
I did a search, was really sure I'd find something, but nope.
On a 71, I would imagine it was designed to run with leaded gas. It is ok to run unleaded, or should I be using some sort of additive?
Reason I ask is a buddy had a 72 Dodge pickup, and he ended up having to do a valve job. Something with the valve seats... need to be hardened for unleaded?? It's been a while and he didn't explain too much.
Use additives. My friend uses a bottle every other fill up on his 71. His origional F has 450,000 miles and runs like the day it was made.
The mechanic I consulted on this issue suggested that it really isn't going to make a lot of difference on a rig unless you make a lot of long, all day highway speed trips. I suppose it is an issue of relative significance, depending on the miles you put on your rig, and how hard you drive it, but the bottom line for me is: I don't do it. If you are really concerned, perhaps the best thing to do is have the valve seats hardened when you have the head worked on.
I look forward to hearing other folks' comments on this.
i would also get the head redone with hardened valve seats . but after rebuilding the whole engine! . other wise i wouldn't worry about it . like IDAVE said i think it is only a concern .on how hard you drive your rig . under huge loads . pulling heavy trailers .or long-uphills .
Yeah the Cruiser is just a budject rig, so having the head redone just for the valve seats isn't an option at this point.
Don't really plan on putting too many miles on it, just maybe a weekend here and there, etc.
I checked at Napa and the lead subistute is about $4 a bottle, good for 20 gals. Would make fillups pretty spendy to use everytime.
In another post I read, someone said Marvin Mystery Oil would work the same, is that the case? I have a couple bottles of this stuff.
From what I gather from doing a google search, unleaded gas is "ok", but lead gas would be better.
BayCruiser said:
not thats its exactly legal, but if you do want it, and can get it, avation gas (80 or 100 LL ) is the way to go. Works wonders on my 69 GTO with the stock high power heads.
How many of you remember the old gas pumps where you turned the dial at the pump for the amount of octane? 130 really works wonders... :D
hey, so that lead replacement crap they have been pushing on us in australia is crap?
we just got rid of leaded petrol at the start of 2005.
i don't even remember lead in canada it's been quite awhile ,since 1990 no lead in gasoline. i used to drive across the border to point roberts to get it i have never used an additive . in my chev 350 . using heads off of a 67 ,327 (soft valve seats)
at least 10yrs daily driver . engine runs great and still passes our aircare requirement for clean engines . we follow the california clean air act . now . i do get some slacker requirements .
