Larger oil filter?
Winter Park, CO.
Hey guys,
I was using the 90915-20004 larger filter that I was getting from cdan. Now that he's not around anymore, I am looking for a source for a larger filter. What are you guys using for oil filters? When I enter the 20004 part # on toyotaonlineparts.com, it just comes back with the smaller YZZD3 filter.
Thanks,
Dace
You could use the Napa Gold (Wix) filter. I believe it's the 1515 if you absolutely need to have a larger filter.
Does anyone like the Purolator gold filters? I saw they came out on top in one of those "cut open a filter and measure the media" tests.
I did read really good ratings on the Purolator PureOne filter several years ago. Just stay away from Fram.
Same here. Wix 1515, purchased in bulk for a discount from Fleetfilter.com. They fit all of our Toyotas except a 5.7 Tundra.
I have used the 1515 but went with the smaller Toyota filter last oil change since I was at the dealership getting something else and was surprised at how cheap the filter was when I asked. The smaller filter is a bit easier to maneuver down into position. I don't see the need for a large filter unless you need the extra media to handle extended oil change intervals which I never see mention of among this maintenance hyper forum community.
wix 51515XP if you run synthetic. goes in both my 40 and 80 now
yeah they just came out with the XP this summer. made for full synths. the first one is in the 80 now.
When speaking of synthetic, you must be referring to the filter media of the XP. Before switching to a Donaldson oil filter for my Dodge/Cummins, I used the Wix synthetic media version for the Cummins and I believe it had the XP designation.
Yes but not specifically engineered to use with synthetic oil.
the link i posted actually says "designed for full synthetic oils"
but yes im quite sure it will filter any oil
On a side note: a bottle labeled "synthetic" has only to contain 12% PAO's.
Mobil 1 makes a larger filter that works. I think it's the M203 model but don't quote me on that. I have one screwed on, just can't remember the model number.
If you are a AR-15 guy, you'll remember if it's a M203 ;)
(that's the designation for that 40mm grenade launcher that mounts under the barrel)
