Have you had the catch cans on it the whole time?
Vent the catch cabs to atmosphere, not back into the intake. This takes vacuum pulling oil through the PCV of the table. Then you're back to blow by.
I partly agree with @COYS , if everything is good, you should be able to fire it up and run it without really having to do anything special. Especially with factory fresh Toyota button end.
Having said that, running it in should see it used through every part of the rev range. Hitting 2k rpm is barely getting it above idle. You're barely getting it to operating temp. Parts aren't going to get hot and expand fully, and won't bed in fully.
In racing circles in Australia people say "if you want an engine to run hard, run it in hard".
On an old Aussie landcruiser forum, it was common for guys to have oil consumption issues and blow by issues in freshly rebuilt Toyota diesels. Its almost always guys who treat the new engine like it was made of delicate crystal, and bauxite idle it around for the first 10k km.
Loading them up and getting them good and hot is often the solution.
So long as you're not a peanut about it, you're not doing anything the engine wasn't designed to do straight out the factory door.
