I ordered the grape solar 105 watt panels (2) one for the FJ one for the camper. I ordered the sunforce 10amp controller for the FJ and the 30 amp for the camper, so I can add panels . They came in yesterday, so I need to install everything
Solar Panel - Grape Solar 100w thin (.12") 20"x40"
Phil - I've been looking at 100W Mono panels for a bit. Here's the one's I've been looking at...
Instapark 100W Mono - $197 - https://www.amazon.com/gp/product/B004OZJ4FY/?tag=ihco-20
Renogy 100W Mono - $149 - https://www.amazon.com/gp/product/B009Z6CW7O/?tag=ihco-20
then, when I saw your link I found...
Grape Solar - 105W Mono - https://www.amazon.com/gp/product/B00GGCK7V8/?tag=ihco-20
But I don't think that is the Grape you're using (there is no way it is .12" thin!)... Could you point me at the one that you purchased (on Amazon or anywhere else)? Curious about the price...
Mount solar panel to a thin piece of steel and then mount the steel to the rack????Here is the thin panel.
http://www.grapesolar.com/photo-flex-100w.html
I bought the thin panel as well, I'm having difficulty trying to figure out how to safely mount to my new Baja Rack...I'm concerned with the wind getting under the panel and tearing it off the rack and also any wind noise associated with...
Thoughts?
Stainless or Aluminum is probably the way to go.That's what I'm thinking Mark. I was looking at Stainless or Aluminum though.
Thanks.
If you want to go to extremes, use a thermally conductive copper or aluminum filled epoxy to laminate the panel to a emissive painted/finned extruded aluminum panel. It will help keep the solar cells cooler, hence more efficient. Then again, if you want to add metal for mounting, why not just buy a framed panel in the first place?
Silly question maybe, but what's on the Puma circuit that is of any interest to the solar side? Or did you connect the output of the regulator to the Puma battery leads using them as part of the charge circuit?
Also - now that you have mixed 4AWG and 10AWG wire, probably want to fuse at that junction appropriate for 10AWG wire so you don't catch things on fire should you have a bump somewhere.
And looking at 10AWG annealed copper fusing current, 330A or so, the crimp connector may make a good enough fuse if the worst happens.
