Land cruiser 100 AHC problem
Fluid should be somewhere between the "min" and "max" lines on the reservoir when in N position. Many leave it closer to "max."
What does motor sound like and how long does it run hen trying to raise to H?
I had what seems like same issue. Motor probably clogged with bad fluid now gel. Easy to take motor off and clean it.
Im still waiting for vci cable to arrive for the techstream analysis then only proceed for troubleshooting
The motor sound normal. No weird sound is heard. The Led of Hi flashed 2 times then go off by itself.
In the interim, while you wait for the mini vci to arrive, you can try turning each front torsion bar clockwise by an equal amount of turns (something like five turns each should give you a read on whether this helps) . It may lower your pressures enough for the system to raise to high.
