C1917 if I am not mistaken is the 3 core Radiator that has better cooling capacity tan the A1918. Its the recommended radiator when redoing the cooling system.
I've got the C1917, but based on reports from the Southwest (Tools or LC Phil??), the A1918 in aluminum actually has a couple of degrees cooling advantage. The C1917 is a bit less prone to damage, but try to avoid sticking trees through your grille and you should be fine with AL.
My understanding is they both fit all years with the 1FZ motor.
