koito headlamps on switchpro
im getting close to having everything other than the air lockers finished. headlamps work great, and switchpro emailed me back with directions on having that gang auto on with the key on, so no need to activate headlamps at the switchpro before trying to turn then on via the oem dash pull switch. i tied the switchpro dimmer trigger wire into the passenger side front marker lamp, so the keypad inside the cab dims when lights are on. i still need to run my stereo, compressor and air lockers. not sure if i will buy their adaptor harness (switchpro that mates to arb harness) or try to figure out my own.
Finished the switchpro install and got everything buttoned up the way I wanted. This is a great option for anyone running several electrical devices and isn’t worried about something not oem or period correct. I ended up with an adaptor harness from switchpro for the lockers and compressor. The phone app is great and allows for some really customized settings, like memory and color, brightness, momentary, etc etc. the headlamps gang is set to memory, always on with ignition.
View attachment 3794059View attachment 3794060Finished the switchpro install and got everything buttoned up the way I wanted. This is a great option for anyone running several electrical devices and isn’t worried about something not oem or period correct. I ended up with an adaptor harness from switchpro for the lockers and compressor. The phone app is great and allows for some really customized settings, like memory and color, brightness, momentary, etc etc. the headlamps gang is set to memory, always on with ignition.
Looks like the switch pros can also run 2x17A from a single switch so you could wire your headlights independently if you wanted. That is a pretty slick setup.
