Knuckle Overhaul Going Bad
Montgomery Co. TEXAS
Website
missionsonwheels.org
I'm in the process of assembling my '78 knuckles. This is the second time I've been into them but can't seem to get the driver's side axle back in. The setup is stock '78 knuckles, clearanced for Newfields with stock inners and I've run this for a couple years now. For some reason I can't get the axle to seat into the housing. It stops about inch or inch-and-a-half short and won't budge. Never had this happen before....what's the deal???
rotate the driveshaft...is it catching the teeth on the side gear?
2 person job tho, one rotates the shaft, the other pushes/wiggles the axle into place...
Gotta hold your mouth in the corret orientation as well!
Also if you have one side in.. You might need to rotate it as well.. It's catching by the spiders and not engaging. I remember being stuck at that exact point for a couple days once a # of years ago..
Here is another piece of advice while rebuilding knuckles. Don't track grease in house. Wife don't like it. Also, I have three German Shepherds that help grease up the rugs. NOT GOOD!!!!!!
J.R.
76 FJ40
350 Chevy/SM465/NP205
Dana 60/14 Bolt.
If you look into the differential, you will notice that the diameter of the side gear is smaller than that of the carrier. This means that you have to elevate the end of the axle shaft before it can slide into the side gear. the teeth have to be aligned also.
The trick is to use the seal as a fulcrum to raise the inside end of the axle shaft about 1/8 inch. Push down on the top of the outside end of the axle shaft, while at the same time pus in and turn the axle and it will slide right in. You may be embarrased at how easy it is once you get the axle end centered over the side gear.
Pin-Head wrote: The trick is to use the seal as a fulcrum to raise the inside end of the axle shaft about 1/8 inch. Push down on the top of the outside end of the axle shaft, while at the same time pus in and turn the axle and it will slide right in. You may be embarrased at how easy it is once you get the axle end centered over the side gear.
Exactly. I did this a few months ago; the only thing I'd add is to go easy on your fulcrum since it'll be holding back your diff oil for a few years. Of course, "easy" is a relative term when you're dealing with horsing a 25# axle assembly into place . . .
make sure you grease the seal and shaft up a bit to keep the texture of the shaft from hurting the seal.
Not only absolutely correct, but very well said. Descriptions like this should be worked into Woody's FAQ page. :)
Can't rotate the axle cuz the birf is not into the knuckle far enough. I'll keep dink'n with it today but so far I've done all the above mentioned tricks (including the grease on the kitchen floor). It feels like something is gett'n wedged or bound up somewhere. The birf stops right where the flat surfaces are going into the knuckle and is hard to pull back out. Maybe I just got lucky in the past but I've not this problem the last two or three times I've had it apart.
try loosening the steering arms, don't remove the nuts, just back them off 1/8", top and bottom....perhaps you've added enuf extra preload to the bearings to squeeze the axle slightly....
ya, I have hard a hard time getting axles out before because of to tight a preload. loosen the bottom cap and that should do it. If not you may need to do what Pin Head said about having to push down on the axle to get the end up and into the carrier. Other than that what Woody first said will get it the last inch or so. Nothing else to catch you up.
That got 'er! Owe ya nuther :beer: When you coming down this way again?
I had to remove a thin shim on the top to get the preload set...parently a little snug. Loosened the steer'n arm and it slid right in. Guess I don't understand now the steer'n arm would effect the birf.....but I'm kind'a slow that way.
66fj40x2 said: I had to remove a thin shim on the top to get the preload set...parently a little snug. Loosened the steer'n arm and it slid right in. Guess I don't understand now the steer'n arm would effect the birf.....but I'm kind'a slow that way.
Most likely your knuckle was slightly out of alignment with the axle housing when everything was torqued in initially. So when you tried to seat the axle, the birf hung up on the knuckle housing.
Glad you got it done.
