knuckle bearing/ races
Raleigh, NC
i am currently trying to install new races for the knuckle bearings, and they are both (top and bottom) half way in, but will not go in any further. I have been beating on them violently with a heavy hammer and block of wood. they are in farily level and need to go down just a bit more, but stopped moving. I put them in the freeze for an hour and that did no good. I have put a large C clamp on the knuckle ball and tried to press them both in at the same time, but no luck. I need some tips/ tricks asap. I got the old ones out easy. I am using Trail gears kit. I have read over 4crawlers site, but no help.
Thanks
They go in rough sometimes... I'd go to a metal place and get a 4 inch long piece of round brass that is wide enough to cover the whole race. Also hitting that axle with a propane torch may help spread it out a little... Good luck!!! :cheers:
