knocking noise
What general location is the noise coming from?
What year is your truck?
Its a 97, the noise is coming from the middle of the Cruiser, sounds like the Transmission-or in that general area and only happens wheni shift into Drive from Reverse, other that there are no noises what so ever. It's 100% stock 131,000 miles
The driveshafts have 3 grease fittings each. If they get dry, a metal on metal noise can be amplified though by then sometimes damage is done. At any rate I'd have the driveshafts greased and see if it makes a difference. Be sure to look in the FAQs about overgreasing them and causing damage.
Generally, this is typical of a vehicle with a bit of slack in 2 drive shafts, 3 differentials and a dozen gears in the drivetrain. No big deal.
DougM
