My chinook/lx450 project which sits for months at a time developed a funny knocking or clanking sound on the passenger side of the block. Seems to be higher up in the engine between 4 and 5 piston but it's hard to tell. The engine revs and idles smooth. When you give it gas from idle it's gets slightly louder and varies with speed. As you get up to speed the sounds seems to go away but not sure if this has to do with all the other noises droning out. There are no other abnormalities. Temps are good actually quite low. Acceleration seems good. The only thing I noticed was the oil pressure seemed low at one point but seems fine now after changing the oil. I drove it like this for a 200 miles and didn't seem to have any I'll effects other than maybe the sound was a bit louder on startup.
I've run the truck without all the belts so it's not the steering pump, belts or a/c. Cap and rotor seem fine. Any ideas?
Valve clearances or sticking?
Clogged injectors?
Spark plug not seated?
I tried to pull all the plugs but the plug wire bushings got stuck on some and I ran out of time.
The valve cover seems to be leaking so was planning on pulling this as a next step but would like to hear any other suggestions.. I've read a lot of other noise threads but nothing seems to be similar.
Clogged injectors?
