Knock
The Ghetto
Driving my cruiser yesterday aand after I opened up the other two barrels a big ol' knocking came from the engine. I finally stopped, got out, opened the hood, and the knocking sounded like it was coming from the driver's side of the engine. After about a minute it seemed to correct itself. Probably not but the knocking stopped even when I continued to drive it. I thought my front drive shaft split in two because it sounded like the knocking slowed as I stopped the vehicle. I'm thinking a lifter that might be busted under the valve cover. Not sure. I haven't opened anything up yet but maybe someone else could shed some light. :eek:
Most of the bad things that make a knock don't just go away by themselves. I'm guessing that you heard "preignition" knock when you jumped on it and then you were dreaming when you listened to it with the hood open.
I hope that is right and it isn't something more expensive.
Wow. That sounded like an early Christmas gift of advice but I know what I heard. It sounded like s*** and it stopped on its own. I don't think it had anything to do with my ing sys. I think it was a busted lifter that almost made it's way through the valve cover at my head.
Howdy! I used to have a 72 FJ40 with a 350 in it when I lived up in Cheyenne. Especially during cold weather, it would knock noticably for the first few minutes on a cold start, and then it would gradually go away. It turned out to be a tired hydraulic valve lifter. It would be a little sticky when it was cold, and once it got warm and lots of oil flowing to it, like magic, it would cure itself. The engine had over 100,000 miles on it with minimum maintenanc when I got it, so I did an oil change every payday(no filter), until the oil stayed real clean, and the problem went away. Didn't cost me much over $50. John
Ok. That could be. I've also noticed a decrease in HP especially going uphills. It seems like it's choking.
Howdy! What kind of carb setup do you have? Could be the choke is not opening all the way, especially common when the weather cools off. Could be a vaacum leak. Could be floats set too high and it is flooding when nose high. John
I have a 70s-80ish Rochester Quad. Could this be a cam issue?
Howdy! Maybe. What did the 350 come out of? Vettes and Cameros are set up for higher rpm ranges that truck motors. The carb sounds stock/original, do you know if the cam is original or not? If it is souped up a little like an Edelbrock Torquer Plus or more, then the good power doesn't even come on until you get past 1500 rpm. Mine is basically stock, all original, from a 77 Chevy sedan. It is pretty tame, but I can idle it down to about 300 rpm on the trail. John
300 rpm? Nice. Not sure what engine came out of. PO did the swap along with a "Stage 2" cam. I'm assuming souped up is what he had in mind but i'm thinking I knocked something loose inside the heads with the knock from before but I noticed the dec HP before the knock. Although, I did something pretty retarded and washed the engine when it was about 160 degrees. Maybe I have a crack in the block. I have an oil leak now that's not noticeable except for that it's dripping onto my exhaust and creating that Spy Hunter smoke screen when driving. Not good.
