I'm sure it would work well. I would spend the extra money (retail $169)and get a Scangauge II, it does the same thing, plus a bunch more. You can choose from about 10-15 standard gauges (gallons per hour, mpg, avg mpg, air intake temp, coolant temp, cost per mile, open/closed loop, rpm, mph, load, HP...), trip info for current trip, day, previous day, tank, you can add any custom gauges that are supported by the ECU, on the LC I know you can add fuel trim, O2 sensors, fuel inj pulse width, and probably some others. You can adjust the mph and mpg to your tire size/gearing.
