How about a device that locks all the wheels? I put a a couple of solonoids on the out lines of the master cylinder. Similar to a line lock. Looks and installs like a line lock, but will only let fluid through when 12V is applied. After power to it is turned off, i push down my brake pedal and all wheels are locked. No moving the car until 12V applied to the solonoid. It's a
standard Parker valve sold at Industrial supply places. Gets installed opposite the fluid flow arrows shown on the valve.
Parker has no less than 50 versions. Either + or - or any combo to activate, and models with various Volt ranges and amp requirements to operate. I use an ignition on power source with a hidden toggle switch in series. I usually only use one for the front brakes, but used two on my cruiser cause it's so valuable to me
It's a Parker Skinner valve part# 7121kbn1nf00n0c111c1
best used in conjunction with a hood lock.
A kill switch won't work for me. I don't have a coil or trans nuetral switch
