Eyedaho
This sounds like a good idea to me. Any concerns about having another possible failure point to shut off your rig while you're driving? I assume that your momentary switch latches a relay while you start the rig, but then what signal do you use to keep it latched while the rig is running? IGN power circuit?Kill switch is good if you remember and use it.
I wired a kill system that auto resets every time you shut the ignition off. To start the ignition needs to be in the on position and you press a momentary secret button to complete the EFI circuit and then it will start. If you do not complete the sequence all it does is crank. Once you shut the engine off its start over. It is so seamless many watch knowing and never see the secret.
ETA: I guess I answered my own question. Haha. I think I'll use a momentary switch with 12V constant to latch a relay, then IGN 12V to keep it latched. In my 100, but same concept. I'd like to just bypass the pesky immobilizer and do this instead.
