Is there a writeup on how to do this on a 3FE?
Been trying to figure this one out. When my rig, '95, is loaded climbing a hill I need to smash on the gas pedal to get it to downshift. Oftentimes, it only downshifts for 1-4 seconds.
What cable do I need to adjust?![]()
The procedure for adjusting your throttle cable (kick-down cable) can be found in your FSM, just follow said procedure and you'll be all set.Is there a writeup on how to do this on a 3FE?
PS: To tight = hard shifts, to loose= floating shifts, just right= perfect shifts
this is probably the one thing that you can do on the truck that takes literally 5 minutes and will give you back some power. It was immediately noticeable after I adjusted mine correctly. The FSM outlines the procedure step by step.
ThisThe procedure for adjusting your throttle cable (kick-down cable) can be found in your FSM, just follow said procedure and you'll be all set.
