Key won't turn in ignition...
Charlotte, NC
Yes I have the right key. :p
I even have a few spares and non of them are working. I tried the steering wheel jiggle, even rocking the cruiser a few times, banged a few things too. I read somewhere else that it may be a shot key barrel? Anyhow, it doesn't turn at all. Help!
Did you try WD40, graphite, ...
I had a completly worn out key that quit working. After a new one was made it was fine.
I had to really work the steering wheel once to make it work.
Had the same problem,was a combination of worn/bent key, lack of lubrication and slightly worn pins in the ignition lock. Solved the problem with a can of WD40, and 3 new keys, all $20.00:cheers:
My freind just had the same problem get a new code cut key from locks,ith or dealer, worked for him..
I got it working for now.
I got it to start finally. I didn't try anything different other than rocking the wheel and pushing the shifter up. I still have to fanagle (sp?) it to get it to turn. I don't think it is the key as I have 2 other sets and they all do the same thing.
Question, if I wanted to fix this issue would I need to get a new ignition lock cylinder? Are those easy to replace?
Thanks for the feedback and help.
I just had the problem last week. It was an intermittent issue for a few months, then one day the original key stopped working, I switched to the spare, it started working again. To be safe purchased 2 vin cut keys from the dealer. $20.00.
Your keys could been cut wrong, mine were.:hhmm:
