I have a TM-271A and a TM-V71. I used Chirp IIRC.
I have a 271 and yes. I also know folks with 281s and they can as well. You export as .csv as described above.Are you able to read the TM-281 memory with Chirp. The radio is listed on Chirp but cannot receive memory???
I am able to read the TM-V71 but not the 281??? I can read the 281 with the Kenwood software (MCP-1A) so I know it is not a problem with the USB/Serial cable and driver.
Yes, the TM-271A came before the TM-281A. Basically the same radio and both work with chirp.271?
I think I was doing everything correctly but will try again today.
Make sure you're using the latest version of CHIRP. It gets updated frequently and the V71 is older than the 281.No luck with the 281 and Chirp.
The V71 works fine.
The cable is good. I can use the Kenwood software and read/write without issue.
Kinda stumped here???
I have an old laptop running XP and might give that a try.
