KDSS dust boot
kcjaz
Olathe, KS
When my dealer fixed my KDSS he noticed that the dust boot on the front sway bar piston had a small tear. He told me he can’t order just the dust boot and it only comes as part of the whole KDSS assembly which was $1000.
Anyone out there replace their KDSS dust boot? Where did you get the part?
It isn’t listed as a separate part in Toyota’s system.
Might be worth contacting some Australian toyota shops as they have so many 200s that get wheeled hard down there.. they are much more likely to have dealt with this before. Or maybe PM some of the forum users from down under.
sounds like an opportunity for ARB or ICON to come with an aftermarket boot that can be done without taking the KDSS apart ...
The problem is they would barely sell any.
Or if you can find some toilet paper it’d probably work just as well.
Toilet paper?? Have you not been to the grocery store lately?!?! TP is worth more than gold these days!
I’ve been working on something for awhile, and am getting closer.
In the mean time, it’s already got two small access holes in the boot to let air displace. If it didn’t, the boot would be destroyed rather quickly.
it’s a hydraulic piston, just like the ones on construction equipment. The boot just prolongs the shaft life. So if the area the boot is torn, does have the ability to have a stone fly at the shaft, you will absolutely never does tease that shaft’s service life.
Again, if you go missing with a perfect boot, I promise, you’ll get mud inside the boot, so don’t worry about a tiny tear. Only be frustrated for a tare where a tire or another car can pepper the shaft (like exposed Icon or King rear shocks).
Aren't there split boots that could go on there to provide some protection? Like something that would go on a shock or steering stabilizer?
Looks like this got banged up on last trail.
Lower retainer trashed. Guess a stainless steel zip tie could be a good replacement.
Did you guys find a good solution for this? My KDSS dust boot is also torn from the tire rubbing against it. I was thinking of putting some silicone on it, but finding a replacement would be cool...
Bump. I never did find a solution. I just ignored the rip and then ultimately got a different 200 now my second 200 is developed a rip probably due to tire rubbing.
Wondering if anyone tried the flex tape I may give that a go, but suspect it won’t stay in place for very long.
My boot is fine but the minute I got bigger tires the boot slipped the lower clamp and is just dangling. I cut it off and threw on a regular black zip tie as a trail fix and it’s held for 30k miles lol.
Not pretty, but I used a hot glue gun to seal the holes in my boot. It is functional albeit hackinsh looking.
RTV seems like a viable temporary option, I’d just make sure the boot stretched before applying.
It’s white but eternabond is an RV sealing tape for EPDM roofs. That stuff is STICKY and waterproof and I bet would do an excellent job if you could apply it such that the boot stretching didn’t pull it loose
