K2 Bikes
My bike's aluminum and I love it. I think it just depends on riding style and personal preference. Aluminum is very stiff, and you feel a LOT of the road/dirt/rocks riding a hardtail. Some like it, some don't.
That is an old wives tail. How a frame rides is a function of tube size, thickness, and shape. There are steel, aluminum, and titanium frames that ride as stiff as a board, and there are ones that ride like a noodle. Is is how they are built, not what they are built with.
1. Beerman, your dumb :flipoff2:, The frame is much more important. It dictates HOW the bike rides
2. Cary, your right that the design is most important, but at the same time, two bikes built the exact same. one of steel, and one of AL, the steel bike will weigh more and have a more forgiving ride, the AL will be stiffer and lighter.
3. Tonkota, I have always heard of K2 bikes being in the same category of trek, specialized, ect.
Sorry, but it simply is not true. Lets start with 4130 (since you didn't spec the type of steel, 631, 853, Nirvcom, S3, etc.) for the steel and say 6061 Aluminum, and build the identical frame, same size tubing, same wall thickness, same geometry, everything. The steel frame will be nearly 3 times stiffer than the aluminum one. In fact it would ride like a girder it would be so stiff.
I have ridden steel bikes that are rock hard, and currently ride a aluminium framed hardtail that rides nicer than most steel frames (Titus Riddler made out of 6069). Material does not dictate the ride.
cary, i'll take your wiord on it. I sit corrected.
can you explain where the theory that al is so much stiffer than steel (carbon fiber/ Ti) comes from?
Well, I have made up my mind. I called a couple stores in town, and they each said that they have an 80mm travel fork for my Trek and that I should keep the Trek because apparently the 930 is a very good, balanced bike and Trek doesn't use that frame material any longer.
Thanks guys for your input.
What year was your 930 produced? When you install that 80mm fork your current geometry is going to change. How much will depend on how old the frame is. IIRC 1991 was the first year Trek designed the frame around a suspension fork, granted back then a Rockshox Mag 21 had 53mm of travel? Your talking 80mm.
Long story short you might end up with handling characteristics you don't like.
Poorly built AL bikes. In the early days of AL bikes, they were considered whippy noodles, then Gary Klein came along with oversized tubes, going a bit overboard in the name of proving stiffness. Cannondale then jumped on the bandwagon using even bigger, non butted tubes, and their frames were really, really stiff. This started a trend in very oversized tubing, which resulted in an entire generation of overly stiff AL frames.
Here is my roadbike, look at it carefully, is it one of the new generation steel frames like S3 that uses larger thinner tubes, or is it aluminum tubes that aren't massively oversized?
Cary, one minute between posts was not enough time to answer. But clearly it is AL by the size of the TIG welds.
They use Tig's on Steel all the time also, that is the big benefit of later steels like 853, which get stronger as welded and don't require heat treating after being joined.
Let me rephrase the question:
Are K2 bikes better than a Schwinn/mongoose/next/huffy etc? Are they similar in quality of build to a Cannondale, Trek, GT, Specialized?
I just don't want a crappy bike. I am happy with the 1997 Trek 930 single track chromoly frame, but I would like a front shock setup and the neck size is too small.
Shoulda been more specific about the comparison to Schwinn and Mongoose. The Schwinn and Mongoose bikes you get at the big box stores are NOT the same Schwinn and Mongoose bikes you get at the real bike shops. They have two different lines of bikes, and the bike shop variety are actually good bikes. They kinda hurt their rap, but are making very good bikes again.
Hey dumbass. A newbie rider wouldn't be able to tell the difference.
Are you a complete moron? Or do you just act like one on the board?
:flipoff2::flipoff2:
Since steel and titanium are stronger than aluminum, they generally use smaller diameter tubing, with double, and sometimes even tripple butted tubing, and thinner walls.
Also, steel and Titanium ride differently than aluminum, so geometry makes a HUGE difference here as well.
I have an aluminum Gary Fisher Mt Tam Hardtail (Easton Elite 6061 T6 Aluminum tubing) that climbs like a mountain goat, and is an AWESOME bike for XC style riding. Point it down the hill though, and the long top tube and short rear triangle make it REALLY sketchy to the point of being scary.
The ride is also VERY harsh on anythign but hardpacked dirt, and smallish gravel.
My 'big' bike is a Transition Dirtbag, which is also 6061 T6 aluminum, and has 7" of suspension front and rear. This bike ROCKS going downhill, but climbing is seriously an afterthought...
IF you're going to spend alot of time in teh saddle, I'd consider a high end steel or titanium hard tail.
If you're only going to use the bike occasionally, a 7000 series aluminum hard tail will suit just fine.
It's all in how much you want to spend, and what kind of riding you intend to do.
Personally, I won't own another aluminum hard tail.
My next hard tail is going to be either a steel or titanium 29er.
:popcorn:
yes but the weld puddles of steel are much smaller than those of an AL joint. I guess my point was why post the question if the answer was only 60 seconds away?
Because I couldn't figure out how to put the answer in the same post, but below the picture.
K2 doesn't even make skis anymore, they just import them from China. Can the Chinese make a decent bike? quite possibly. Does K2 know that much about bike making? Doubtful.
most of the carbon fibre bikes and bike parts out there are made in china.
Many chinese products suck.
However, they seem to hit the nail SQUARE on the head when it comes to Carbon Fibre production.
:popcorn:
Here are my 2 rigs.
I dig the Thermoplastic from GT and the Aluminum on the Azonic serves a great function for overall weight on a 50lb bike.
I'd stay away from K2 and try and fly with a Gary Fisher as someone mentioned. Just remember, you'll probably ride it MORE than you think and want to hold on to it longer than you would think so buy accordingly.
Whatever you do..enjoy...riding is a blast.:beer:
Waste of Money.
'nuff said. who would ever want something like that, and i'm not too sure, but i don't think anyone would trust it to go off of "big hits," as in sidewalk curbs?
