- Thread starter
- #41
Thanks SBG. I'll explore it tomorrow morning and report back.
Then, it is almost like it not getting fuel in follow on attempts to restart truck.
Sounds like what my 61 was doing. Try removing the hard line from the carb, and then removing the fitting that it threads into, it should be 17mm. Be careful you don't drop the washer, I did but luckily found it. Once the fitting is removed you can use a flashlight to look inside and see if the filter is clogged. Mine was packed solid with crud.Update:
Ensured hard line feeding into tank wasn't clogged. Re-primed lines with fuel and started truck. The truck finally stayed running under its own fuel cell for the first time. Stayed running for five mins with good oil pressure, temp, and no smoke. Decided to give it a go and go for a test drive. I got about a 1/3 of a mile down the road and the truck just died.... Ran great up to that point too. Tried restarting, the truck starts idles well and after 15-20 seconds, it dies.Then, it is almost like it not getting fuel in follow on attempts to restart truck.
So, I'm guessing that I have carb issues. Not sure where to start.![]()
Good call SBG! The bottom of the hard line feed into the tank was completely clogged. I took the hard line assembly out from the top of the tank and took ametal cclose hanger and clean gas to it. Problem solved. Buttoned everything back up and truck started right up. I took the truck out for about a two mile run. She did great and I hit 55mpg with no isuue.SuperBuickGuy said:I think your issue is still in the tank, but it's darn hard to see from here (it's dark)
