Just a few points
Vancouver, BC, Canada.
Website
www.paool.com
Hey guys, i've been lurking around the site for a little while now, and I checked the search on most of the items on the list, but couldn't really find what I was looking for.
Anyways, the story behind this all, is that I imported my 78 FJ40 to canada (specifically BC) and to be able to insure it, I have to pass an ICBC inspection, its quite thorough and I knew I'd fail, but I needed to have a list of what to fix. So I have 30 days to fix these items or pay 160 dollars for another full re-inspection, where they might catch things they missed the first time around.
not to waste time I'll only put the things I need some clarification on.
The first thing on the list is The Bellcrank bushings... I looked throught he haynes manual back to front and front to back and can't find any mention of this part. I know its in the steering system, or near it, but not sure exactly where. Maybe I call it something else, but I just can't find it.
My dash lights do not work... well they do, but the guy checked them in the daylight, so as with any cruiser i've ever seen, they are super dim. Anyone know the best way to brighten these things up with minimal work? (time constraints)
the front signal lights are loose... the bolt is stripped or something, I spent a good hour trying to tighten it, shim it, anything, but its still too loose. Anyone know how to disasemble these? The nut on the bottom is rusted on pretty good, and there is no where else to grab it to stop the whole thing from spinning.
Thats pretty much it... If anyone has any helpful info that'd be great! Pretty simple things, i know, but I'm at a bit of a loss as of how to fix them.
Welcome.
Bellcrank-
14mm bolt on top that threads into a larger nut looking affair...that is where you adjust the free-play. Back the 14mm bolt out a turn, and then tighten the larger nut piece..22 or 24mm, iirc, till it is snug, and then back it off a 1/4 turn. Do this AFTER you have given it a liberal amount of grease from a grease gun.
If after doing this, and there is still play in this component, you will then need to install a bushing kit to make it pass your inspection.
Dash lamps-
They all suck, period. Replace them with something better.
SOR, and possibly others sell some very bright replacements that seem to work really well in the trucks that I have installed them in/seen them in.
Turn signals-
They all rust, and do what you are talking about. Most likely will need to be replaced as the fastener that positions the signal base is rusted junk. Can get some cheaper knock-offs on ebay or CCOT.
Good luck!
-Steve
Perfect! Thanks for the help!
Though I need some clarification on where exactly the bell crank bushing is located. Its right near or on the pitman arm correct? The inspector said I had to replace the bushing completly, so Tightening it isn't an option... unfortunatly. Its too bad too, cause the play in the steering isn't all that bad at all.
I guess I'll just hack off the signal lamps once the replacement ones get here. I wish they made ones that where seated completly on the fender, not on that stupid post thing.
While I'm at it, I need to replace my front and back leafs and shackle bushings. I'm thinking of just ordering up a lift kit + SR from MAF, CCOT, or someone else any suggestions? What rides the nicest?
Center arm kit you will need to get one of them and install it. The center arm, or bellcrank is forward of the front crossmember. It is not that difficult to do...you will need a puller to get that steering arm off however...
I am an OME fan, but have heard many positive things about CCOT hell for stout lifts....A customer orderd a 4" that he wants me to install in his 79-40 sometime in the next few weeks...along with a litney of other mods...
There are many good vendors out there....MAF sells a quality SR kit that I have installed quite a few of.
Good luck!
-Steve
On the dash lights. They can be made brighter by pulling the cluster out of the dash. Then pull the speedometer out of the cluster. Look for the housings that the lamps are in. Gently rock them back and forth until they break off. Reassemble the cluster without the reflector housing pieces. Then the lights work a whole lot better. Didn't see a writeup in the tech links but I know there are a few floating around between here, Pirate and the LCML.
Nick
Not sure if you have a "PartSource" store in BC, but they have LED replacement bulbs for your dash. I'm sure they have them elsewhere, I just saw them there.
HTH
Is the "bushing kit" you referred to in an earlier post the same as a Center arm repair kit? If so, why not just replace the Center arm?
Actuall I was looking at the entire MAF 4 inch lift kit with the SR. Its the most complete kit I can find, and the price isn't too too bad. brake lines, shackles, bushings, and OME shocks. Pretty much everything I need. Whats your (or anyone elses) opinion on this set up?
If you are good with a small diameter die grinder, you can make a diagonal cut into the nuts on the base of the turn signals and they will separate from the studs. THen all you have to buy are new nuts.
I have done this numerous times. It takes patience [and a good faceshield!] but can be done.
Best
Mark
BTW, there are other sources for 4" lift kits.;)
great idea will remember that
Best
Mark
actually, for the signal lamp issue, I started doing what you suggested (cuttin the nuts off) but stopped halfway and had an idea. I opened the lens of the lamp, took a drill and drilled a diagonal hole downwords till it went through the Signal light housing.. the post, and finally the fender. Then I took a fairly long screw and screwed it in till it was snug. That fixed the spinning play that it had and Its much more solid now for sure. Then I took twine and wrapped it around where the post meets the signal lamp housing and tightly wrapped it around several times. That stopped the forward, back, and side to side movements and now the whole assembly sits tight. You can hardly see the twine at all even from right up close, and you can't see the screw from anywhere but underneath the wheel well, and through the top of the inside of the signal lamp. Kinda ghetto I know, but it'll work to pass inspection... plus now they dont move.
I'm an OME suspension fan myself.
If you want to replace the center arm as a whole you might end up bustin the bolts that hold it on, but that's ok just put new ones on. I would recommend a replacement, I rebuilt one once and it didn't seem to last too long before there was noticable play in it again. It is the biggest PITA in the steering system. Just go with Saginaw PS to eliminate that POS when you have time.
Also fought with those PITA signal nuts, just cut em off with your grinder and order up new ones. It's not worth the ongoing fight, trust me.
Congrats on your new cruiser and welcome to the forum!
:beer:
