It certainly could be made to fit a flat surface. Would require you to remove two 3" tower like mounts though. You would loose one of the mounting studs and a plastic clip.
Just another bit of info... the license plate itself WILL come in contact with the Slee rear bumper latch plate (on top of the rear bumper) when the tailgate is completely open. (see 1st pic in post #6). I have not figured out a sure fix this yet. The only thing I can think of is to remove the plate and shave/grind down the bottom of the plate by a milimeter or two and reinstall. To be honest though, I am ok with it for now.
I'm wondering if it could be trimmed to fit a flat surface, say my Kaymar jerry can swing out?
Thanks Beowulf! That's a great idea. I will fix that this weekend.
Have you got your Cruiser back, yet? I'm just trying to find out if this JDM Relocator would clear the Kaymar with the tailgate open. The pic shows what I'm worried about. The minimum space between tail gate and bumper you can see is 5/8" or about 16 mm. The thickness of rubber gasket and plastic frame at that point would determine if I will have clearance problems or not.80t0ylc - My Cruiser is in the shop getting a new head right now but that's another story but I can get some measurements when I get it back on Fri. or Sat. though........
Thank you SCFZJ80!!! Your efforts just saved me some $ and headaches. From your pics I could determine:80toylc - Here are some pics. I'm not sure if it will work with yours but these may help. It appears that the thickness of the bracket, plate and plate holder is 3/4 to 7/8"..........
I "think" the GX model with the barn doors came with something that might work. (The curviture might be a bit different between them and the lift-up doors, but nothing that you should not be able to work with).
