Is there a power difference between a JDM spec 1FZFE and a US spec.
When you get past 1997, the ratings for the 1FZ that remained in production in other countries, goes up with the modification of the intake manifold, ignition system and I "think" variable valve timing on some 2006+ engines.
Kind of wish we got those engines.![]()
Yes, for instance in Venezuala the 1fz has these stats (fzj79):
Potencia máxima (SAE Neta) (Hp/rpm) 220/4600
Torque máximo (SAE Neta) (Hp/rpm) 384/3600
Thats what i was thinking. I have heard of som supra guys doing a 1fzfe swap but hood modifacations are a must.
Anyways just scored a rolled 93 with a 65k mile JDM engine with paper work that will find its way in my 97(cruiserdan thanks for the tips on the crank sensor issue). It has some very interesting stainless steel headers on it that the PO said came with the engine when it arrived to the US. Also has a Teq oil cap.
in AusWhen you get past 1997, the ratings for the 1FZ that remained in production in other countries, goes up with the modification of the intake manifold, ignition system and I "think" variable valve timing on some 2006+ engines.
