jacking up the cruiser
my cruiser might be slightly lifted. this is a dumb question but how do you guys lift your cruiser? i am missing the factory jack if it came with one.
i really need to change the brakes!
I use a floor jack with jack stands for safety when doing maintinace, harbor frieght 17" bottle jack for possible flats on the road, hi-lift for trails.
Don't just use a jack.
I knew a guy, since passed on, who worked without chocks and jack stands. When I met him he was a paraplegic. When the car he was working on crushed him it took 4 hours for anyone to notice. 4 hours after that they figured out how to lift the car off of him. He lived another 40 years on crutches.
Make sure you're on level ground.
Chock the wheel on the other axle opposite of where you're working. Chock 2 wheels for added peace of mind. Pull the parking brake lever -hard-. The parking brake on these becomes ineffective if they aren't used. Do not trust the parking brake to hold the truck. Particularly if you are working on the rear axle.
I usually break the lug nuts 1/4 turn or so loose on the wheel to be serviced before putting the truck in the air. This way I'm not putting a bunch of torque on the wheel which can turn the other wheels.
With the truck in park and one wheel in the air, these trucks CAN roll. Chocks are important.
Use jack stands. When servicing one wheel I put a 6 ton stand on the frame and a 2.5 ton stand under the axle.
If you have it in the air and you don't like it, bring it back down, reposition things and try again. Having a 5,000 - 6,000 lb truck in the air over the top of where you're working is a serious thing. Treat it as such.
I'm not a mechanic and I don't work for AAA. At your own risk, etc... IMHO YMMV.
go ahead and spend the money to get a good floor jack and a set of heavy duty jackstands. I had my old truck roll off a bottle jack once before and almost crush my leg. Don't even get me started on hi-lifts, those should be strictly trail use.
... i am missing the factory jack if it came with one.
Get a stock jack, they are good for changing tires and a ton of other jobs on the trail.
thanks guys, i was just curious of how to jack up the freagin truck because it was so high up...
i have a floor jack but the thing won't even reach the frame rails with it even if it's fully extended up.
...the thing won't even reach the frame rails
Put the jack and jack stands under the axle, like MikePL suggested. You don't need to reach the framerails.
You should use a proper floor jack. If yours won't reach then you can use a 4x4 or two as a spacer under the frame. Then get it up on 6-tonne or 12-tonne jack stands. As others have said, working under your truck with inadequate equipment is dangerous and potentially deadly.
-B-
