Sheet-looks like I'm gonna have to step up my game to hang with Jrob now![]()
u r full of sheet!!!!
not going to move it that far!..............................................yet.
Jrob I like the looks of this one for you:
Consider flipping the springs. All you need to do is cut/relocate the hangers on the axle to correct the pinion angle and you have a bit of a stretch and it still looks like a Cruiser.
Why a toybox? I can't imagine why you would do that over an Orion.
Toybox? Thoughts there?
It's "no brainer" as in easier to fit... right? "bolt-in" application. what does it take to fit an orion? cause i want a box as well... so i need this question answered...
An Orion is a bolt-in direct replacement. No driveshaft mods, not shifter mods, just lower gears.
A toybox in a FJ-40 makes the rear driveline crazy short and the front shaft even longer.
I see no reason at all to not go with an Orion. If built right it is trouble free and 4:1 with the 4:1 first gear is a great combo on the road and trail.
Not for split case from my understanding. If so then why are they not used in 60's?
Bomar, Orions just work in FJ-40 cases. If you wanted to run one in a wagon you would need to put source a case from a non-split case truck to bolt up behind your 2F.
4 speeds are a dime-a-dozen.
