that's 7-pendantic.I find this thread slightly pedantic.
- jonheld
I guess I was assuming it had some off road purpose. Seems like not much of one.
If you ever get to the switchbacks on Black Bear Pass and a few other places where you don't want to be fighting tire scrub on tight turns, you'll know.
so what one is the pin 7 mod then @jonheld ?
Fixed it for you...
From the FAQ at the top of this forum.
LOW WITHOUT CENTER DIFF LOCKED
Post #45 by the infamous @cruiserdan.
Pulling a stump at the edge of your yard, in a cul-de-sac.I still don't get the use case for this "mod.". In what scenario would you want the center diff unlocked in Low?
ah, I was being a smart arse but thank you.![]()
Here in the northeast we have some very tight trails. Having 3 open diffs makes negotiating them much easier. It puts less load on the driveline and won't cause understeer. This was the very first "modification" I did on my 91 about 25 years ago, although I simply pulled the plug off the transfer case.I still don't get the use case for this "mod.". In what scenario would you want the center diff unlocked in Low?
Not so much...
Yes. 91/92 don't need anything else. On later trucks, the pin 7 mod changes shift points as well as ABS. Since the A440F is 100% hydraulic and there's no ABS, there's no need for the mod.I didn't even do the 7 pin mod, Uh I mean pin 7 mod. I just unplugged the wire on top of the transfer case. 91-92 80's already have the transfer lock switch on the dash.
Can you use the hazard button as a CDL switch as well?
