My previous searches of a m8000 installed in an ARB came up empty - so I posted the question. I'm no stranger to the search function. The reason I asked is because no one has posted (that I can find) about specifically the m8000. I'm assuming these winches have subtle differences between each model excluding the obvious (their pull rating). From what I see and have experienced - this doesn't bolt up without some modification or fabrication which is slightly disheartening because Warn and ARB both say it mounts right up.
If I remember correctly treerootco mounted his behind the grill somewhere. He has the Slee shortbus and a 9.5 Warn winch, might try a search...
Sorry I was not trying to imply that you should try searching because it was a stupid question, etc. I couldn't think of the thread that treerootCO posted in so I thought I would suggest searching under his threads... I found it: https://forum.ih8mud.com/80-series-...us-alternate-winch-solenoid-mount-option.html
Maybe that will help?
Thanks for the link - its a little tough to see what's going on there if you haven't done or haven't seen these parts.
you guys are fags....
Mike,
I probably have a bracket in the shop somewhere if you don't find yours.
Cheers,
Michael
Now that's a slick bumper. From what I understand - the synthetic line is more durable, safer and lighter than the steel cable. The only reason why I have it is because I bought the whole set up used.You can run it up in the engine bay right in front of the battery. Thats where I put mine... Cleans up the front of the truck a bit, and keeps people (or debris) from messing with it.
look'in good. I turned my non-winch mount bumper into a concealed winch mount. It has a Warn 9500 tucked up in there with about a 3/8" plate welded to the inside...that makes for one thick deer smacker if you include the thickness of the ARB.
I'd like to get rid of the roller fair lead and go with the winchline style like you have. Looks much smoother, but seems I'm in rocks mostly my winchline might get chewed up so probably the cable is the better option for me.![]()
Thank you for making my Cruiser want list even longer.![]()
that bhousing is way too clean, come over so I can throw some dirt and grease on it.....
u going to rubithon or not??
's BFF to her parents house in Grand Junction - I wanna meet up with some local fellas and hit up Moab
. I may or may not be towing my popup to camp.
