It won’t charge!
Dfw
1966 40... it’s starting to cool off here in the DFW area in the evenings, so I’m starti back up on my project. So when I got the thing it was not charging. Because I’m trying to put this thing back together the way it was I had the altanator re built, painted, and I’ve re installed. Ordered oem regulator and have installed. Still not charging. I’m thinking the regulator may not be hooked up right. It’s the way it was when I took it apart, but who knows if that was right.
I’m going to tak a pic to see if it worth posting. Not a bad pic... left side is two white with black strips, top right is white with red stripe, and bottom reght is white with green stripe. Also I have a good ground on the altanator. I’ll take a pic of the altanator as wellThanks for any advice!
Is your battery in good shape? Fuses/fuse block/connections at fuse block?
Fusible links did not appear until the 1972 model year. I do make a kit to allow you to easily add one to your 1966 FJ40.
The below assumes your amp meter is connected and working. If it is not the alternator will NOT charge the battery as the amp meter is in serials with the battery and alternator.
If you have a DC volt meter check the following:
With the truck running you should have +12V on the White/Red wire at the regulator. (That wire should be attached to the regulator Ig terminal, the White Green goes to the F terminal, and the White/Black to the E terminal for ground)
The White/Red wire is the B+ voltage the regulator uses to know how much charging needs to be done. This wire goes back to the fuse panel so check the fuse that has the White/Red wire on it. If you do not have that +12V it will not charge.
If you do have the +12V on the White/Red wire, and all the wires are connected in the correct place then verify that the regulator is grounded well. It grounds through the mounting bolts for the regulator. If you did not clean out the threads for the bolt holes that mount the regulator, it may not be grounded well. The White/Black wire that attached to the E terminal (Earth or Ground) is the MAIN ground for the entire vehicle! So if the regulator body in not grounded well, neither is the rest of the truck...
Still no charge after verifying the ground? Set your meter to low OHMS and meter out the White/Green from the regulator to the alternator plug. First unplug the alternator plug to isolate the White/Green and White/Black wires. Put the red lead into the connector for the Green/White wire and the black lead on the Regulator White/Green wire (F terminal). You should have <2 ohms or good continuity between those points. Do the same for the White/Black wire. If these are good then leave the connector out of the alternator for the next test.
Testing the alternator:
To check the alternator itself you will need to make a jumper wire or clip lead long enough to reach from the alternator to the battery + terminal. Attach the end to the battery + terminal then put your meter in DC volts mode and put the red lead on the battery + and the black lead on battery -. Write down the reading. Should be about 12.7 to 13.2 volts if the battery is fully charged. Leave the meter connected to the battery and start the truck.
Use the clip lead to CAREFULLY and momentarily, apply +12V to the alternator terminal the Green/White wire was connected to. This is the F terminal. Doing this will cause the alternator to go full field meaning it will put out maximum charge current. The volt meter should now read 14.0 to 15 volts if the alternator is working. Do not leave this connected for more than the time it takes to look at the meter!
If it passes this test then you have a bad regulator or a wiring issue. If it does not pass this test you have a bad alternator...
@Coolerman That`s a great explanation of the test procedure. It all seems so simple until it`s your charging system that`s not working. LOL!!
JP
Thank you all. Coolerman, you make something that seems complicated to most understandable. Thank you!
So here was the problem. It was the fuse. I looked good so I assumed it was. After testing with both my test light and for continuity I got zip. I replace the fuse and now I’m getting 14 plus amps
Bill
No fires.
The fusible link for an FJ40 is a simple piece of 14ga wire covered in a special insulation that won't burn, though it will smoke like hell if it blows.
This small wire goes in series with the larger 10ga charge wire to the battery. If you get a major short in the 10ga wire (like say you forget to take off the battery cables then attempt to remove the dash cluster and short the amp meter terminals to ground) then the large current flow will cause the smaller 14ga wire to melt in two before the large 10ga wire catches fire. The smaller 14ga wire is capable of carrying the 35-40 amps the FJ40 is capable of pulling because it is short and has little resistance.
The retro fit kit for your 1966 is easy to install. You remove the 10ga White wire from where it attaches to the starter B+ stud. Cut the large ring terminal off the 10 ga white wire. Install the fusible link in its place using the special connector that is provided. Attach the other end of the fusible link with the large ring terminal back to the starter stud. Your main charge wire is now protected!
