Issues starting
musthave
All maps, one app!
Supporting Vendor
Florida / Colorado
OEM Alternator is about 1 year old battery is about the same. Battery has good charge. Fusible links are less than a year old.
Rather suddenly I have an issue whereby when I turn the key I get 1 short "click". If I turn it to off and do it a 2nd time it usually starts right up without issue. Only once has it been a 3rd time.
Thoughts as to what that might be?
Sounds like the starter. I'd pull it off and replace the contacts or replace the whole starter.
While the starter is out swap the fuel filter if that hasn't been done in a while.
Contacts are an easy job, depending on the starter, maybe worth it. The dealer "kit" price is pretty close to a reman starter. We often use aftermarket contacts, not rocket science, just hunks of copper. For reman, our go to is Denso 2800169, can be had for ~$90.
First check is resting battery voltage, then attempt to crank, what is the voltage? Terminal condition, clean?
