Is this ball joint my problem?
Heber City, UT
I’ve been experiencing an annoying mild but audible click/clunk coming from the front end. This happens at low speeds, mostly when turning. It even happens when turning the wheels in park (on top of a couple of sheets of cardboard to reduce unnecessary forces). I’m unable to reproduce it with the wheel in the air, trying to elicit play with hands at 3 and 9 or at 12 and 6.
I don’t think it’s cv joints (clicking when not rolling). I wonder about inner toe rods but probably need a second hands on opinion.
On visual inspection, the only thing I can see is leaking lower ball joint boots:
Driver’s side:
Passenger’s side:
LX is 2017, has 116,000 miles. AHC lift. 295/70R18
The sound seems to coming from PS but the DS LBJ looks to have leaked more.
Does a LBJ make a clicking noise when it’s on its way out?
Make sure your LCA cam bolts are tight. When mine loosen up, they act like you’re describing.
PS- my LBJs have looked like yours for as long as I can remember.
Same.
Really hard to judge ball joint condition on appearance alone.
OP maybe try forcing the knuckle into different directions using a prying implement against the LCA. Beyond that I'd suggest getting ahold of a set of chassis ears.. sortof the easy button for tracking down noises like this.
^this the prybar.
Thank you all for the good advice. My alignment cam bolts were about three clicks below torque spec (207 lb-ft) but that didn’t resolve the annoying click.
I also retorqued the bolts for my skids and found two that were one full turn loose. That was the sound! Now I can empty my parts shopping carts of ball joints and tie rods and sleep easily.
