Is the original stereo worth anything to anyone?
For those of you looking to maintain OEM looks in your Cruiser, I have installed Bluetooth receivers and amplifiers in classic cars and trucks for many years. Everything is hidden and not associated/connected with the original head unit in the dash. You simply use Spotify or Pandora playlists, MP3's or any audio content you can find on your phone to drive the system. This preserves the original look of the dash but gives you a rockin stereo. These units support A2DP (stereo music audio) There are a large number of low power combination Bluetooth/amp combos on Amazon. Some good, some with quite a bit of distortion. Higher power systems require a separate Bluetooth receiver with a line level output to drive the amp(s). Make sure the Bluetooth receiver has sufficient output to drive the amp to full volume. Some are a bit anemic in that respect. I have only seen a few Bluetooth receivers that have reasonable noise cancellation to have a microphone that will allow effective cellphone voice call use. And most of them have a head unit that you would have to hide in a center console or glovebox. For this feature it must support HFP.
One manufacturer (ecoxgear) has taken the music connectivity to the next level. Their Bluetooth receiver can re-transmit to other receivers with their tech and all systems play the same content. Multiple vehicles (or boats) within range (about 30 feet), parked together, can all be playing the same music. They also make amplified soundbars and portable speakers.
RichmondBob, what are you trying to accomplish? There are lots of options.
The '97 that I have under restoration is getting a double DIN head unit, full speaker replacement (Polk and JBL), custom speaker grills to look stock, custom sub cabinet hidden in the RR fender-well and a 5 channel (JL Audio HD900/5) amp. I will be integrating that with GPS, OBDII inputs, 5 tire pressure monitors, HDMI inputs tied to an Amazon FireStick, rear view/backup camera, Android Auto USB connectivity, USB 3.1 charging and hub as well as LTE modem connectivity with WiFi. I may take apart the FireStick remote and put a button someplace and remote mount the microphone. My only purist deviation...
Also toying with a thermal front facing camera. Building a USB interface for that to display on the head unit as well.
The bluetooth link from the head unit to the phone is working OK, but as I mentioned earlier, the audio quality from the little lapel microphone that they supply leaves a lot to be desired. I will probably start on a noise reduction microphone hunt after I get most of the interior back in the vehicle and see how much that quiets things down.
I am working with the guys at Samsung to see if we can figure out how to get new Samsung DeX application working with bi-directional communication for head unit touchscreen operation of the phone. Lots of possibilities there.
Good question - here's the list:
  1. Keep OEM head unit
  2. Add Bluetooth capability via OEM head unit to stream music and (bonus) make/receive phone calls
  3. Add amplifier *if* Bluetooth unit volume is low
  4. Change OEM speakers in all four doors, cargo area (above sliding windows), dash (at knee level)
  5. Change centre console speaker to a mini-sub (I believe that speaker's no more than 6")
  6. Apply sound-deadening (w/ heat barrier) matting to interior
Priority is keeping the (1) OEM head unit, (2) adding the Bluetooth unit and (3) amp if required.
Run that for awhile and add the rest as I feel required.
+1 to 1,2,3
+1 to 1,2,3
We men are but simple creatures and yet women refuse to believe this, hence, Landcruiser.
Back to the original topic. I am looking for an original radio for my '92. IT has lost sensitivity and the display is no loger working. It looks just like the OP's radio. I have no interest in a modern head unit. An old Pioneer super tuner of the correct vintage would be good too. Please PM me if you have a working radio that you are interested in selling.
