I thought I would add my 2 cents, I have run open and run with air lockers, LSD's, factory E-lcokers, detroit locker and now cable lockers. Hands down as far as the most reliable and easiest to use would be the cable lockers, however they are also the most expensive to aquire the factory toyota ones. Here is a good example.. I recently built up a truck for Moab, the truck was pretty awesome to start with (JDM thanks to Luxury Imports) However I really wanted lockers and was going to need them for stuff I was going to be doing at Moab, I could have done with ARB air lockers for about $1800 - $2000 that would include compressor and lockers front and rear (I do the install myself). I decided to go with factory Toyota lockers that's two complete axles and all the factory cabling from G&S and that was $4200.00 (including duties shipping all that stuff). Was it worth it, they work great!!!! would the ARB's work just as well, I am sure for the most part they would, as far as maintenance and upkeep the cable lockers would be less work in the long run.
The point is if you can get cable lockers for FREE do it, if nothing else you never use them but from a value stand point you are ahead of the game.
As far as when to use them and not to use them it is a matter of what you are really wheeling on. I have done what most suggest, see how well you can do the trails open. However I can say all the trails I have done that on you really could do open. Now there are some that most just will not try open but go to some real (accurately rated 4-5+) trails like some found at Moab and you will find that you can try all you want open but you are just going to fail or break. It all comes down to this.....Do you do trails that really require lockers or just makes it easier??
Now as far as lockers and using them go, 80% of the time if you are on trail that require lockers you really only need the rear locker. I would always suggest using the front locker sparingly and engage and disengage often so you maintain your steering and minimize Birfield breakage.
Ok aside from the lengthy answer the bottom line is cable lockers swap from LSD for free.....Are you out of your mind!!!! of course you do the deal!!!!!
Cheers,
Michael
Cheers,
Michael
I'm all about budget.
