crushers said:if you are going to pull the head then you could open up a whole new set of concerns...
cheers
Isn't that the truth. Anyway it looks like there is pitting into the intake valves even though it's not as bad as the exhaust. just curious did you run the engine with the valve cover off to see what kind of flow you were getting to the rocker? might switch up to a lighter oil for startup. I run 5-40 rotella syn.
Good luck alex.
