ok, i'm often helping others with pricing, but it's harder to price your own stuff that you've poured your sweat into. i want my 65 40 done and to do that, stuff has to go...including my 68. i've got over 15 into it...is 6k too much to ask?
sb350, saginaw p/s, tilt column, 6 point cage with seats mounted off cage (but not mounted to frame yet), new alternator, new radiator with taurus fan, soa, shackle reversal, spring reversal, conferr shackles, rancho 9000s, 4.56s, aussie locked in rear, good 74 body, removable nerfs, rear bumper with leds, heavy a.. front bumper with tow bar mounts (tow bar isn't included), fj60 discs, all pro high steer with custom ricebilt rods and new 80 series ends, custom aluminized exhaust with magnaflow, 36" radial swampers on custom cut chevy rally wheels, full size spare (never run), sm465, toy 3spd xfer with tcase saver, ford shock towers, tuffy overhead console with cb, map lights and sony am/fm/cassette/changer control, tuffy fenderwell boxes with sony speakers, heavy duty diamond plate corners (not the crap the sor sells), edelbrock intake and carb, optima battery, oem floormat, blockhugger headers, cut rockers with angle iron. stainless brake lines, mudrak xfer output seal conversion, rear cv driveshaft with new joints.
now the bad, 3rd gear needs work to fix a common sm465 issue, no winch, never finished reinforcement of the front xmember from the saginaw conversion, i'm keeping the rear full floater setup and swapping in a stock cruiser rear. inner rear fenderwells are rotted through where oem rollbar mounted, i'm also keeping the land cruiser replica bezel, i'm also keeping the oem replica softtop and oem doors, will come with a corrugated top and harddoors if interested, rattle can paint job (but it looks good on this pos
), windshield glass is busted.
