I just put ironman t-bars in along with a steel bumper and a M12000 warn winch. I love the way it holds together and the ride is much better than the OME i had on my other truck. I plan on hitting the trail next week...i'll report back in.
If you plan to wheel your truck the Ironman setup is out for me. Sure, the ride is OK and not harsh however they do not articulate as well up front because they are too high a rate for our weight. It take a ton of force to compress your front.
My SwayAWay T-Bars are in between the Ironman and OME. If available back in 2001 I'd a preferred the OME because I need every added articulation improvement. The stiffer your Tbar the more the wheel will not compress and therefore the more the opposing wheel lifts in the air. I can't imagine what amount of front weight it would take for the Ironman's to work as well as SAW or OME. Between an ARB, winch, and lights we're about loaded!
Here's an example of where a softer (smaller) Tbar pays off. The PS compresses well and the DS stays on the ground. Put a stiffer Tbar on and that PS wheel doesn't stuff as far so then the DS wheel comes off the ground.
Wish the factory Tbars could handle our modified weight. They move easily throughout the travel.
I think if a fully loaded 100 is flexing like in shotts photo, it will compress with any setup... The driver rear must come up and over that mound, putting most of the weight on the passenger front... you saying it wouldn't compress fully even with a truck as heavy as yours?
My logic tells me the following.
Stock vehicle weight (i.e. 5000lbs) with OEM T-bars vs. Stock vehicle weight (i.e. 5000lbs) with IronMan T-bars
Results = Stock vehicle's front end will flex and articulate much easier than the vehicle with IronMan t-bars.
Stock vehicle weight (i.e. 5000lbs) with OEM T-bars vs. aftermarket vehicle weight (i.e. 8000lbs) with IronMan T-bars
Results = Stock vehicle's front end will flex and articulate the exact same as the vehicle with IronMan t-bars.
In my mind, the larger diameter T-Bars do not overall flex less than stock diameter bars. The larger diameter bars just require more weight behind them to achieve the same overall flex as OEM bars.
your logic is correct.
However shotts seems to be stuck on this theory that anything larger in diameter than his SAW or the OME setup, itll be like riding in a dump truck, and it will be so stiff you will get wheel lift going over a speed bump...
Thanks
I think shotts is correct in the sense if you put IronMan t-bars on a stock weight vehicle it will probably ride like sh!t. However if you put IronMan on a appropriately aftermarket weight vehicle then the ride will be similar if not better then stock.
Suspension is all about application, what is the goal and configuration of your vehicle, select accordingly.
Thanks
I just wish I had something in the rear, those 866's don't like to compress with no weight back there
Exactly...to compress (cycle the suspension) the same you need a balance between weight and rate. If the weight stays the same and you put on a stiffer spring/Tbar then ease of compression suffers. If you put on a weaker spring then it cycles easier.
Of course you need overall balanace...rate vs weight. I think my SAW Tbars are too stiff for an ARB+winch+lights. I'd bet my bars that the OME's would work/cycle better.
that makes no sense. your OEM bars were meant for a stock weight truck not supporting 800+ extra lbs
Please re-read. I said I'd prefer OME, not OEM. I think the OME would match the rate better than my SAW bars for this weight vehicle.
OEM
OME
The abbreviations couldn't be more confusing!
Then there's SAW....wasn't that a movie?
OEM
OME
...Sorry, I have nothing to contribute today...
