Ironman 4x4 Panhard Bushings
Denver, Co
I'm replacing the bushings on my LX450 using the Ironman4x4 kit. When replacing the front panhard bushings the new ones just drop in to place. Which is a much different experience I had replacing the radius arm bushings that required me to press them in. I double checked to make sure I was using the correct bushings from the kit. The ironman4x4 bushings about 1mm smaller in diameter than the bushings I am replacing. I have contacted Ironman4x4 but doubt I will get a timely response since tomorrow is Thanksgiving. Has anyone run in to this problem?
I don't think that's right. It needs to be a proper press fit. I've found over time that going with OEM avoids this nonsense. Even poly has its own dumb issues either at initial install or with time.
I had to press my ironman bushings in
