IP problem if 1HDT
Philippines
Good day, newly registered tho l waa a member before but haa not accesses my account for years.
l adjusted Air fuel ratio on my 80 series diesel, to make it lean as it was smoking like my griller & slurped diesel like a hog. Now it does not start any more. Inquired from a local mechanic & he said adjusting screw spring inside the IP may have fallen off.
Would appreciate any advice how l can DIY this. TIA
Romalc
Try posting this in the 24V/diesel section. Those fellows will help a little faster.
When messing with your pump make you need to keep track of changes. If you adjusted the main you should try stepping on the throttle while trying to start, rpm will decrease or increase depending on which way you turned the screw. Obviously you turned the fuel down.
