introduction and some troubleshooting
Santa Cruz Mtns
Hello, my name is Damon and I am an addict :D Recently purchased a 96 80 and been driving it everyday for a little over a week. Loving it! Going to this truck after DDing a 60 for 6 years is a big difference. Did I say I love it!?
Been diving into all the FAQ stuff... lots to read. Did a search, the best I could, to find info on what I am trying to troubleshoot. Nothing has come up yet so was hoping to tap the collective mud brain.
Bit about the truck: 96, Js, Ls, MAF panhards, Slee castor plates, 35 Truxus, DC front driveshaft, Landtank MAF, elockers, 4.88s, CDL
(1) Noise at speed...
When Im driving anywhere from 40-70 everything seems to be fairly quiet and smooth at first. Then a noise will start. It sounds like I am hitting those warning tracks on the side of the road just not as loud (there may be a bit of hesitation when the noise occurs but not sure yet... kind of like of like something is "grabbing"). It appears to be comig from the right side of the truck. At first I thought this may be the right front tire in combination with groves on the road but change lanes and the noise continues. Let go of the wheel to see if it would pull to the right any harded but nothing... it doesn’t pull to the right any more than it usually does (pulls just a tad). Started testing what/when it makes the noise. Letting off the gas it "goes away" (maybe it doesn't really go away but the loudness of it goes away and its not noticable), accelerating it appears to "go away" as well and when thrown into neutral it goes away. The noise really only seems to happen when I am on the gas at a steady speed. Any thoughts you have would be great!
Ujoints maybe? Got under the truck last night to look for possible play in the DS ujoints f/r... rear really didn’t have any (both hands-push/pull-up/down-left/right) and the DC front had a tad but not excessive. Its my understanding that a ujoint would *typically* make noise when accelerating and letting off the gas (not 100% sure this is always true)
I was thinking to try a few runs on straight sections of freeway with the CDL on and see if that alters the noise at all... Would this be worth trying? Maybe the increased load to each shaft or possible ABS/brake issue? (i do get peddle oscillation when braking and steering wheel shake)
[STRIKE](2) Whistle...[/STRIKE] EDIT: Solved... thanks for the help guys! :cheers:
there is a whistle sound when accelerating quickly or "getting on the gas". Its almost like a noise that tells me "Im not being economical with the throttle". Sounds like its coming from the rear somewhere. Any ideas? I cant track it down and it does not appear to be related to the "noise at speed" question above.
As always... any and all help is appreciated! :beer::cheers::beer:
Thanks!
First off welcome to the 80 addiction.
My first thought would be u-joints. Try pulling your front drive shaft off, lock your CDL, take a test drive.
The whistling noise is common with 80s, I believe its your rear resonator. My whistle disappeared after cutting it off. Sounds like you may have a warped rotor as well.
Good luck and lets see some pics of your rig.
Steve
...that whistling noise when accelerating? Did the PO forget to tell you about the turbo he installed? :p JK, I as well as many others I've read, have the same whistle from the exhaust....very common and not a problem. Good Luck with the 80!!! :cheers:
Thanks for the help... gonna pull the front shaft first and then the rear.... will report back in a few days
And thanks for the welcome :flipoff2:
Sounds like U-joints are going south on you...this would be my first place to start...and welcome to the club!!!!
Problem solved. Lower caliper bolt worked itself all the way out
After I put the bolt back in... it appears that fixed the peddle oscillatoin as well. Still going to pull things apart to check for damage (pull PF wheel, check pads/caliper/surrounding area for dampage, re-torque bolts on DF caliper) and drive it around some more.
The "noise" I have been hearing came back. (edited main post)
Pulled the front DC DS front and engaged the CDL. Hit the highway and NO noise. :D If I understand things correctly... this means its not the front axle or the pinion (pinion is still spinning). It seems to me that its the DC joint in the front driveshaft. Does this sound feasable???
I was planning to reinstall the front DS and hit each zirc with grease. While I was down there thought I would grease the rear as well.
Any advice is appreciated!
:cheers: Happy Holidays and Merry Xmas Eve!
Next on my xmas list...
Its a waiting game to see if my CEL comes back on after the reset. Yesterday... reset the EFI (pulled the relay under the hood on DS fender) and replaced both O2 sensors.
What is the noise exactly? Is it the first one you describe, like driving over the warning strips?
Do you have cogged or smooth belts?
Its the noise I described in (1) in the initial post.
I will have to check on the belts.... give me a few minutes brb
Belts are smooth (on the pulley side of the belt)
I think I narrowed the down the noise by removing the front shaft....
Do you have a DC DS? Perhaps your caster isn't correct for your DS or your U-Joints are going out.
Not sure what you mean by "on the pully side of the belt." OEM belts should be smooth on both sides.
Yes, DC front DS. Im leacing toward the ujoints going out.
Are there some measurements I could do to look into caster being the issue? (or should I just start searching :D )
Thanks Ebag333... the help is appreciated!
EDIT: the belts are smooth... I was referring to the inside of the belt.
