Intro
HI Everbody Im wayne from NZ (south Is) I have a jdm bj 74, with 13bt (standard but not for long... need more power!) 4af trans. cable lockers front and rear. currently running 33's:)
cheers guys will post pics asap. i only have rural dial up internet (very slow... think 2L in hilux with 33's and standard gearing.) need some advice on increasing boost. do i need to adjust injector pump or will compensator do it automaticaly?
do you have a rotory pump? do you have a boost compensator already? if so then it should compansate accordingly. you can crank the fuel up on the rotory pump 1/3 turn...
cheers
