Intro thread - 1997 LX450
Understood. Thanks for the advice. I am mechanically inclined so not afraid to tackle the above list but have a few questions (sorry for any dumb ones:
  • What do you recommend addressing for cooling system, hoses, thermostat, fan.....?
  • What is the PHH and how do you swap it?
  • What is the LSPV and how do you adjust it?
  • Rear heater lines? Are they similar to rear A/C lines in a Suburban? Or are you referencing the heaters under the pass/driver seats?
  • The guy I bought it from had a receipts for repairs, one of which was the valve cover gasket. The shop also recommended the rear main seal and front crank seal. I can see where they are/have been leaking, but it doesn't leave any drips in my garage or driveway so should I worry about them or just be vigilant about checking oil level?
  • Head gasket, rig has 185k miles, so when should I think about changing it?
  • The antenna is broken, what are your suggestions? I hear the motor, but it doesn't move.
  • The 3rd row seats are there but the brackets underneath as well as the long arm are messed up and need replacing. Where do i find those parts, junkyard?
  • Last question (for today, haha) where is the best place for OEM parts? I have used sparks parts in SC for my 4runner in the past, but they don't really handle Lexus unless the part is identical to the Toyota.
Again, sorry for any stupid questions and thanks for any and all help! Happy Thanksgiving!
Welcome to Mud where there are no stupid question, only stupid answers............. :D
  • What do you recommend addressing for cooling system, hoses, thermostat, fan.....? OEM Parts, fan my be just fine, most swap to green coolant for availability
  • What is the PHH and how do you swap it? Slee - PHH (Toyota 80 Series Land Cruiser)
  • What is the LSPV and how do you adjust it? LSPV with 2.5" OME
  • Rear heater lines? Are they similar to rear A/C lines in a Suburban? Or are you referencing the heaters under the pass/driver seats? Under the seats. They can rust out and delete helps eliminate heat in the summer.
  • The guy I bought it from had a receipts for repairs, one of which was the valve cover gasket. The shop also recommended the rear main seal and front crank seal. I can see where they are/have been leaking, but it doesn't leave any drips in my garage or driveway so should I worry about them or just be vigilant about checking oil level? Check YouTube for how to vids
  • Head gasket, rig has 185k miles, so when should I think about changing it? all trucks are different. I have one with 230k that needs it done and another with 282k on the original head gasket and phh. Just become aware of the symptoms and invest in a ScanGaugeII
  • The antenna is broken, what are your suggestions? I hear the motor, but it doesn't move. you will either learn to replace the drive ribbon every so often or just get a solid mount antenna. they break consistently
  • The 3rd row seats are there but the brackets underneath as well as the long arm are messed up and need replacing. Where do i find those parts, junkyard? junkyard or the classifieds section. many don't use their 3rd rows
  • Last question (for today, haha) where is the best place for OEM parts? I have used sparks parts in SC for my 4runner in the past, but they don't really handle Lexus unless the part is identical to the Toyota. I have Onur for that. I just send him pics and parts show up.
Thanks again! Sounds like I need a heated garage so I don't have to wait for spring to start working on it.
Good looking truck...spitting image of mine! LOL My 15yr old daughter :princess: named it Green Bean.
I just went through the entire cooling system and changed all the rubber lines and the thermostat.
Changed all the Vacuum lines too and deleted the EGR while I was in there.
These things are old enough to vote, and the rubber under the hood shows it.
Do a search for the PHH, its been VERY WELL documented. I deleted my steel riser tube and went with the Wit's End kit to make life easier in the future. Wits' End Solutions for 93-97 80 Series Land Cruisers
For parts, I've found there are no "one stop shops".
I have bought from: Wits End, Toyota Parts Overstock in Lakeland, my local Toyota dealer, Rock Auto, local AutoZone (they had brakes in stock) and probably half a dozen other places. The LX450 is an FZJ80, all the parts are interchangeable except the grill and head light trim.
Just upgraded to TLC shocks over the LX shocks, makes a HUGE improvement in road manners.
Antenna, go to a fixed mount if you want to ditch the power one, its a DIRT SIMPLE install. Another MUD search will reveal the "secret".
The rear heater lines are galvanized steel and on mine were just about rotted out, caught them just in time. They are between the cats and the passenger floor boards under some heat shields. I pulled mine and looped the hose back on itself, but will be putting a new set in; kids are complaining its "cold back here".... yeah yeah yeah, cry me a river,:cry: I grew up in a 70's 'burban in Upstate NY.
Front main is fairly easy to replace other than the main bolt requires 300+FTlb of torque. I need to borrow a 3/4drive torque wrench before I tackle mine. "While you're in there" do the O-ring for the distributor shaft and the oil pump cover gasket too. While I'm in there I'll be rebuilding the PS pump too.
I haven't played with the LSVP, that's on next months list. Its a proportioning valve that links the rear frame to the rear axle via a leverage arm and a needle valve inline with the rear brakes. The lower the rear end squats the more rear braking you have, the valve assumes "squat"="load". Its been rumored that deleting it is an improvement. :meh:
If it helps, just remember you have a ready made hobby in the drive, and you can always find an excuse to get out from under the missus feet, cuz there is ALWAYS something that "needs" attention. If nothing else its high enough off the ground to roll under it for a nice nap.;)
Thank you for all the information. It sounds like I will be busy for a long time.
