Good looking truck...spitting image of mine! LOL My 15yr old daughter
named it Green Bean.
I just went through the entire cooling system and changed all the rubber lines and the thermostat.
Changed all the Vacuum lines too and deleted the EGR while I was in there.
These things are old enough to vote, and the rubber under the hood shows it.
Do a search for the PHH, its been VERY WELL documented. I deleted my steel riser tube and went with the Wit's End kit to make life easier in the future.
Wits' End Solutions for 93-97 80 Series Land Cruisers
For parts, I've found there are no "one stop shops".
I have bought from: Wits End, Toyota Parts Overstock in Lakeland, my local Toyota dealer, Rock Auto, local AutoZone (they had brakes in stock) and probably half a dozen other places. The LX450 is an FZJ80, all the parts are interchangeable except the grill and head light trim.
Just upgraded to TLC shocks over the LX shocks, makes a HUGE improvement in road manners.
Antenna, go to a fixed mount if you want to ditch the power one, its a DIRT SIMPLE install. Another MUD search will reveal the "secret".
The rear heater lines are galvanized steel and on mine were just about rotted out, caught them just in time. They are between the cats and the passenger floor boards under some heat shields. I pulled mine and looped the hose back on itself, but will be putting a new set in; kids are complaining its "cold back here".... yeah yeah yeah, cry me a river,
I grew up in a 70's 'burban in Upstate NY.
Front main is fairly easy to replace other than the main bolt requires 300+FTlb of torque. I need to borrow a 3/4drive torque wrench before I tackle mine. "While you're in there" do the O-ring for the distributor shaft and the oil pump cover gasket too. While I'm in there I'll be rebuilding the PS pump too.
I haven't played with the LSVP, that's on next months list. Its a proportioning valve that links the rear frame to the rear axle via a leverage arm and a needle valve inline with the rear brakes. The lower the rear end squats the more rear braking you have, the valve assumes "squat"="load". Its been rumored that deleting it is an improvement.
If it helps, just remember you have a ready made hobby in the drive, and you can always find an excuse to get out from under the missus feet, cuz there is ALWAYS something that "needs" attention. If nothing else its high enough off the ground to roll under it for a nice nap.
