Intro and a question
CDA, ID
Hi all.
First off, my name is Laurence, I live in the mountain community of Tehachapi, CA. I just purchased a new to me, '95 FZJ80, non-locked with 166k, which is a bit of a dream come true. I'm still in disbelief that my wife OK'ed the purchase, but she loves it too. Honestly, every time I get behind the wheel I get a huge smile on my face.
So, here is where I am looking for input (and sorry for the long post in advance). The truck came with 35's, which I really like the look of and would like to continue to use. I hate the performance however as I live at elevation and drive up and down mountains often. My plan has been:
(1) Regear to 4:88, which is slightly lower than factory at stock tire size to help with extra tire weight/size.
(2) Harrop elockers front and rear
(3) Slight suspension lift (under 3") to clear the tires for wheeling offroad.
So, I have started calling around for pricing and one of the individuals I spoke with told me front lockers were a terrible idea because it would steer badly. He also said the gearing I was selecting was bad and would be awful on the freeway because the gears are "off road gears". He said my tires were too big and I shouldn't go any bigger than 33's and factory gearing was fine. Lastly he said air lockers were better.
I'm confused now. I have previously lifted and regeared an E150 van to correct for oversized tires, and I actually wished I had gone lower due to the added weight of the tires and smaller sized engine. Is there something different about 4:88's?
Why is a front locker a bad idea if it's selectable?
Is an air locker better than the Harrop elocker?
I get the oversized tires thing; harder on bearings and axles. But the difference of weight from a 305/70-16 to a 315/75-16 is 5 lbs. per tire.
I know everyone has different theories about whats "best" and I appreciate this gentlemans experience and knowledge, but am I way far off?
Thanks!
The guy you were talking with sounds like an idiot. When a front locker is engaged steering will be difficult but if that what it takes to get through an obstacle so be it. That is only going to be for a short distance. A selectable locker will have no impact if not engaged. Gearing changes are made to compensate for larger tires, and like you, in high altitude performance. Lower gears are not just for off road. You need to make the decision based upon your needs. Best thing to do is use your vehicle over the next year, determine what your needs are and upgrade as needed.
I just drove an LX450 with 35" KO2's and 5.29's.
It was VERY responsive, and reminded me of how responsive mine felt when it was on the stock 31" tires. At 70 MPH, it is still about 2800 RPM, perhaps a little higher than I would like for mine., but it will make a big difference for DD in the mountains.
There are gear ratio / tire size calculators that you can compare your stock tires and gears (31"/4.11) to the proposed tires / gears (35"/4.88)
A selectable locker in the front is perfect for these. The Harrops are good quality equipment and being electric don't have the possible air failure that an ARB may have.
I would do a "lunchbox" (Aussie or similar) in the rear and a selectable in the front, then decide what tires you want and gear it accordingly. The 80 series will work fine with 35" tires on no lift unless you plan on flexing out hard. Otherwise, go with the 2.5" lift and you'll be good to go. That being said, since you're re-gearing anyway.....do a selectable in front AND rear.
Use Zuk for the re-gear and Harrops (@justdifferentials )
Budgetary:
Gears: $1500 total F/R
Harrops: $1200 (Front) and again for rear
Lunchbox: $500 (Rear)
Assembly: $1000 total F/R
So, the WHOLE boat with gears and Harrops F/R with assembly would be rough SWAG $4900. I could be way off, but get quotes to confirm. Just want you to know it's not going to be $1500.
Thanks @ppc and @BILT4ME for your input. You guys have confirmed my thoughts.
I used one of the online calculators that allowed me to input all specs and view items such as RPM's at given MPH's and etc. That along with my past experience with regears's and taller tires got me to the 4:88's. Like you said, if the locker is selectable, then it's not a consideration until I need it, at very slow speeds.
Basically I was open to the idea that maybe because this is a LandCruiser there were some differences I was not aware of. Thanks again!
Was it a shop down here in Bakersfield? Just curious so I don't go there if they're give out that kind of advice lol
Ha, no it wasn't. It was a fairly reputable shop down south.
Do you have any suggestions for someone who could install these items in Bako?
I did the lift on mine, not bad at all with basic tools.
As far as gears/lockers I'm not too sure. There's direct offroad and 4 wheel parts. No experience but the few times I've been in or have seen their work it's been good. Mainly Jeeps
Marlin Crawler is in Fresno too which is who I'd go with
Double post
35s & 4:88 in a 80 has been done for decades....
Have you tried to connect with local 4x clubs in Bako? Like Bakersfield Trailblazers to get good shops in the area?
Budgetary:
I'm running 315s at mile high plus, and have the diffs out on the workbench right now. ARB lockers and 5.29s going in! Can't wait to see the improvement in performance.
Harrops was what I wanted, but the $400 extra was just to much for my budget. The air compressor was going in either way.
My friend runs his 96 lexus with 315's, 4.88's, 2.5 inch lift and harrup lockers. We also live in Denver and often drive up past 10k feet in elevation for wheeling. He is very happy with the setup. Whoever you talked to at the shop is an idiot.
I haven't yet but probably will now.
I was just baffled by the person's statements, but he said everything with such conviction that I figured i should invesigate just in case. LOL.
