Internal Winch Controls M12000
I have been messing around with a hazard switch and a rear window switch from a 4runner, to cobble together some internal winch controls (when I get it finished I will post up pic's and a write up).
I think I got the switches working the way I want em to work, now I am ready to connect them up to the winch controller.
The remote control plugs into the controller cover . The five wires of the remote/controller cover, then go to the 4 terminals and the 5th is a ground. I assume one pair of terminals is and in/ground and the other pair of terminals is an out/ground.
Can somebody save me some time and telll me what terminals do what inside the winch control box?
Your adventurous ;)
I'm a sparky, but can't offer any advice to which/what.
Look forward to what we see :D
I used the Slee instructions and it's perfect. If you use a rocker switch (like the old 4R antenna switch) you can skip the DPDT relays.
If you use the LC switch, there is a chance of pushing both at once, so you need the DPDT relays.
