Hey everyone.
93 FZJ80, 260k.
This morning, I drove the truck 1 mile to a CVS, walked back out, and couldn't get it to start. CRANK CRANK CRANK but no start. After about an hour of waiting around, it started back up again. Since, it has been fine. Took it to Oreillys to do a load test on the starting system, everything checks out. This makes me think I'm having some sort of fuel delivery issue.
However, I replaced the pump(new denso), filter, and sender(oem) within the last couple months.
Does anyone know what else controls the fuel delivery? I also cannot seem to hear the pump when I turn the key, and am starting to think my relay may be dieing on me.
I know that the relay has two states, high and normal, and goes on high for a second right when the car starts, to push the fuel into the motor. My first guess is that the relay is not sending that high signal.
First thing I'm going to try is swapping the relay. I feel like if it was a pump/filter/sender issue, then it would affect the truck while driving. The relay is 30 years old, and may just have bad contact.
Open to any and all suggestions. Also going to take the truck to a Toyota shop in SD if I cant figure it out, and they can have fun trying to troubleshoot the fuel system. I do not have the banjo bolt to do the pressure test on the rail.
Regards,
Chris
93 FZJ80, 260k.
Regards,
Chris
