- Joined
- Nov 19, 2014
- Threads
- 5
- Messages
- 31
- Location
- Twain Harte, California
- Website
- www.sierraoverheadanalytics.com
Alright, so I've done a bunch of reading on the 26 code, got new NGK O2 sensors on order - the currently installed ones look fine, but I can't confirm they've ever been changed, and i'm nearing 200k. On startup, truck idles/drives fine. After it's "fully warm" truck drives fine (no noticeable stutter off the line) but idles low/rough at 450 giver take. Going to change the PCV while i'm at it.
If I get the motor "hot" on a long uphill, CEL goes off, idle is better, throttle response is better, power is better, etc. CEL comes back on once it cools off.
Plugs/wires were done 30k ago. Checked the harness 30k ago. Continuity on the ground cable is fine.
Mileage is currently worse than normal by a sight (9.8 on last fill up, 13.5 normal), but i've also been daily driving it on short trips, so
. This is the "safe mode" though for bad o2 sensors. Exhaust smells rich on startup, haven't checked it when it's warm/hot. No water in the oil, and no visible leak near #6, original head gasket though afaik. Doesn't act like it's running on 5 cylinders, but I haven't checked either.
It's been raining cats and dogs and everything is soaked.
I have a long required trip to do tomorrow, and my other vehicle (97 tacoma) just blew the clutch main cylinder, and I don't have a garage to work in tonight.
Question 1: Is it rational to think it might be o2's?
Question 2: Any damage to drive it 300 miles tomorrow, except for the s***ty mileage?
. This is the "safe mode" though for bad o2 sensors. Exhaust smells rich on startup, haven't checked it when it's warm/hot. No water in the oil, and no visible leak near #6, original head gasket though afaik. Doesn't act like it's running on 5 cylinders, but I haven't checked either. It's been raining cats and dogs and everything is soaked.
